ONTAP EMS reference
sfu.ctrllerelmntspershelf events
sfu.ctrllerelmntspershelf EMS events occur when a disk shelf firmware download determines the number of controller elements per shelf that can be downloaded.
sfu.ctrllerElmntsPerShelf
Severity
INFORMATIONAL
This message occurs when a disk shelf firmware download determines the number of controller elements per shelf that can be downloaded.
Corrective Action
(None).
Syslog Message
%s: %d ES controller %s can be updated on %s.shelf%d.
cmdName (STRING): Name of the command issued, such as "storage shelf firmware update".
count (INT): Number of ES controller elements on this shelf that can be downloaded.
pluralElement (STRING): Element or Elements.
channelName (STRING): Name of the adapter port or switch port on which the disk shelf firmware can be downloaded.
shelfId (INT): ID of the disk shelf on which the disk shelf firmware can be downloaded.
