ONTAP EMS reference
sis.metadata events
sis.metadata EMS events occur when inconsistencies are found in deduplication metadata.
sis.metadata.inconsistent
Severity
ERROR
This message occurs when inconsistencies are found in deduplication metadata. This might be due to a failed metadata upgrade. The impact will be very low deduplication savings.
Corrective Action
Run the 'sis start -s -m -vserver vserver_name -volume volume_name' command. This rebuilds the deduplication metadata. If the command fails or if subsequent deduplication runs do not provide adequate space savings, contact NetApp technical support.
Syslog Message
Deduplication metadata is inconsistent in volume: %s%s.
volume (STRING): Volume name.
volident (STRING): Unique volume identifier for cases when the volume name alone is insufficient.
