sis.metadata events
sis.metadata EMS events occur when inconsistencies are found in deduplication metadata.
sis.metadata.inconsistent
- Severity
ERROR
- Description
This message occurs when inconsistencies are found in deduplication metadata. This might be due to a failed metadata upgrade. The impact will be very low deduplication savings.
- Corrective Action
Run the 'sis start -s -m -vserver vserver_name -volume volume_name' command. This rebuilds the deduplication metadata. If the command fails or if subsequent deduplication runs do not provide adequate space savings, contact NetApp technical support.
- Syslog Message
Deduplication metadata is inconsistent in volume: %s%s.
- Parameters
volume (STRING): Volume name.
volident (STRING): Unique volume identifier for cases when the volume name alone is insufficient.
