The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
sis.metadata events
Creating your file...
Your file is ready
sis.metadata.inconsistent
- Severity
ERROR
- Description
This message occurs when inconsistencies are found in deduplication metadata. This might be due to a failed metadata upgrade. The impact will be very low deduplication savings.
- Corrective Action
Run the 'sis start -s -m -vserver vserver_name -volume volume_name' command. This rebuilds the deduplication metadata. If the command fails or if subsequent deduplication runs do not provide adequate space savings, contact NetApp technical support.
- Syslog Message
Deduplication metadata is inconsistent in volume: %s%s.
- Parameters
volume (STRING): Volume name.
volident (STRING): Unique volume identifier for cases when the volume name alone is insufficient.
