The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mgr.module events
Creating your file...
Your file is ready
mgr.module.address
- Severity
NOTICE
- Description
This occurs to inform you of where kernel modules were loaded in memory. This information helps NetApp technical support interpret the data in any mgr.stack.frameaddr events.
- Corrective Action
(None).
- Syslog Message
Module %s loaded from 0x%llx - 0x%llx.
- Parameters
module_name (STRING): Name of the module.
module_start (PTR): Starting address of the module.
module_end (PTR): Ending address of the module.
