mgr.module events
Creating your file...
Your file is ready
mgr.module.address
- Severity
NOTICE
- Description
This occurs to inform you of where kernel modules were loaded in memory. This information helps NetApp technical support interpret the data in any mgr.stack.frameaddr events.
- Corrective Action
(None).
- Syslog Message
Module %s loaded from 0x%llx - 0x%llx.
- Parameters
module_name (STRING): Name of the module.
module_start (PTR): Starting address of the module.
module_end (PTR): Ending address of the module.
