ONTAP EMS reference
mgr.module events
mgr.module EMS events occur when this occurs to inform you of where kernel modules were loaded in memory.
mgr.module.address
Severity
NOTICE
This occurs to inform you of where kernel modules were loaded in memory. This information helps NetApp technical support interpret the data in any mgr.stack.frameaddr events.
Corrective Action
(None).
Syslog Message
Module %s loaded from 0x%llx - 0x%llx.
module_name (STRING): Name of the module.
module_start (PTR): Starting address of the module.
module_end (PTR): Ending address of the module.
