ONTAP EMS reference
netif.excesslinkinterrupts events
netif.excessLinkInterrupts
Severity
ERROR
This message occurs when excessive link status change interrupts occur on the network interface. One or two events might indicate a momentary glitch on the link, but many events might indicate a bad switch port, cable, or network interface card (NIC).
Corrective Action
Try using a different switch port and cable. If the problem persists, replace the NIC.
Syslog Message
Excessive link status change interrupts occurred on network interface %s.
ifName (STRING): Name of the network interface; for example, "e8a".
