      netif.excesslinkinterrupts events
netif.excessLinkInterrupts
- Severity
ERROR
 - Description
This message occurs when excessive link status change interrupts occur on the network interface. One or two events might indicate a momentary glitch on the link, but many events might indicate a bad switch port, cable, or network interface card (NIC).
 - Corrective Action
Try using a different switch port and cable. If the problem persists, replace the NIC.
 - Syslog Message
Excessive link status change interrupts occurred on network interface %s.
 - Parameters
ifName (STRING): Name of the network interface; for example, "e8a".
