ONTAP EMS reference
netif.excesslinkinterrupts events
netif.excesslinkinterrupts EMS events occur when excessive link status change interrupts occur on the network interface.
netif.excessLinkInterrupts
Severity
ERROR
This message occurs when excessive link status change interrupts occur on the network interface. One or two events might indicate a momentary glitch on the link, but many events might indicate a bad switch port, cable, or network interface card (NIC).
Corrective Action
Try using a different switch port and cable. If the problem persists, replace the NIC.
Syslog Message
Excessive link status change interrupts occurred on network interface %s.
ifName (STRING): Name of the network interface; for example, "e8a".
