The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
netif.excesslinkinterrupts events
Creating your file...
Your file is ready
netif.excessLinkInterrupts
- Severity
ERROR
- Description
This message occurs when excessive link status change interrupts occur on the network interface. One or two events might indicate a momentary glitch on the link, but many events might indicate a bad switch port, cable, or network interface card (NIC).
- Corrective Action
Try using a different switch port and cable. If the problem persists, replace the NIC.
- Syslog Message
Excessive link status change interrupts occurred on network interface %s.
- Parameters
ifName (STRING): Name of the network interface; for example, "e8a".
