scsiblade.lu events
Creating your file...
scsiblade.lu.gir.end
- Severity
INFORMATIONAL
- Description
This message occurs when this node completes a group internal rebuild for an LU.
- Corrective Action
(None).
- Syslog Message
Group internal rebuild complete for LUN %s on this node.
- Parameters
LUNSerialNumber (STRING): Serial number of the LUN.
scsiblade.lu.gir.hung
- Severity
NOTICE
- Description
This message occurs when group internal rebuild for an LUN hangs on this node
- Corrective Action
(None).
- Syslog Message
Group internal rebuild hung for LUN %s on this node.
- Parameters
scsiblade.lu.gir.start
- Severity
INFORMATIONAL
- Description
This message occurs when the distributed LUN group commences an internal rebuild.
- Corrective Action
(None).
- Syslog Message
Group internal rebuild has started for LUN %s on this node.
- Parameters
scsiblade.lu.incons.memb
- Severity
ALERT
- Description
This message occurs when the SCSI target identifies a node that has an incorrect view of the group membership for a LUN. The LUN will be unavailable on this node and will have sporadic availability on other nodes.
- Corrective Action
To recover from this condition in HA pair configurations, take over the node with the problem by using the "storage failover takeover" command, and then give back the node by using the "storage failover giveback" command. To recover from this condition in non-HA configurations, reboot the nodes having this condition by using the "system node reboot" command.
- Syslog Message
LUN %s on node %s has an incorrect group membership list. Perform a takeover followed by a giveback of this faulty node.
- Parameters
nodeName (STRING): Name of the node that has an incorrect view of the group.
scsiblade.lu.int.rst.hung
- Severity
ALERT
- Description
This message occurs when the SCSI target cannot complete an internal reset of a LUN. This LUN is unavailable until the nodes that could not complete the internal reset are taken over and given back.
- Corrective Action
- Syslog Message
Access to LUN %s is restricted because an internal reset of the LUN was not completed in %d milliseconds. Perform a takeover followed by a giveback for the following nodes: %s.
- Parameters
lu_int_rst_hung_time (INT): Duration of the internal reset attempt in milliseconds.
nodeName (STRING): Names of the nodes on which the internal reset of the LUN was not completed.
scsiblade.lu.int.rst.pending
- Severity
NOTICE
- Description
This message occurs when the SCSI target cannot complete an internal reset of a LUN in 90 seconds. Internal reset is still pending, waiting for internal reset completion within 10 minutes.
- Corrective Action
(None).
- Syslog Message
Access to LUN %s is restricted because an internal reset of the LUN was not completed in %d milliseconds. Internal reset of the LUN is still pending.
- Parameters
lu_int_rst_pending_time (INT): Duration of the internal reset attempt in milliseconds.
scsiblade.lu.resync.end
- Severity
NOTICE
- Description
This message occurs when the SCSI target internal resynchronization of a LUN is complete.
- Corrective Action
(None).
- Syslog Message
Resynchronization of LUN %s on this node was completed successfully.
- Parameters
scsiblade.lu.resync.start
- Severity
NOTICE
- Description
This message occurs when the SCSI target internal resynchronization of a LUN starts. The LUN is not accessible on LIFs on this node during the resynchronization, but the LUN will recover automatically.
- Corrective Action
(None).
- Syslog Message
Resynchronization of LUN %s has started. The LUN is not accessible on LIFs on this node until resynchronization is complete and the LUN recovers automatically.
- Parameters
scsiblade.lu.resync.timeout
- Severity
ALERT
- Description
This message occurs when the SCSI target internal resynchronization of a LUN times out. This LUN is not accessible on this node.
- Corrective Action
- Syslog Message
Resynchronization of LUN %s on node %s was not completed in %d seconds. LUN is not accessible on LIFs on this node. Perform a takeover followed by a giveback of this node.
- Parameters
nodeName (STRING): Name of the node where resynchronization of the LUN was not completed.
resync_time_out_time (INT): Duration of the resynchronization attempt in seconds.
scsiblade.lu.rtpg.lifs
- Severity
ERROR
- Description
This message occurs when the SCSI Target processes the RTPG command and the number of LIFs per Vserver exceeds 700.
- Corrective Action
Reduce the number of LIFS per Vserver to under 700.
- Syslog Message
The Vserver hosting LUN %s has %d LIFs. RTPG command expects the number of LIFs per Vserver to be below 700.
- Parameters
num_lifs (INT): Number of LIFs on this Vserver.
