The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mgmt.cifssymlink events
Creating your file...
Your file is ready
mgmt.cifssymlink.failure
- Severity
ERROR
- Description
This message occurs when configuration of a CIFS symbolic link fails; the symbolic link might not be available through CIFS.
- Corrective Action
Check the reason for the error and take action accordingly.
- Syslog Message
Failed to configure CIFS symlink. Error: %s.
- Parameters
reason (STRING): Reason for the failure.
vservername (STRING): Name of the vserver.
unix_path (STRING): The UNIX path.
mgmt.cifssymlink.success
- Severity
INFORMATIONAL
- Description
This message occurs when a CIFS symbolic link is successfully configured after a failure.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
