ONTAP EMS reference
shm.bypassed events
shm.bypassed.disk.fail
Deprecated
Deprecated as of Data ONTAP 9.3 because bypass code has been removed.
Severity
ERROR
This message occurs when the system recommends that a disk be failed because it has been bypassed.
Corrective Action
(None).
Syslog Message
shm: Disk %s has been recommended for failure due to being bypassed by the shelf.
diskName (STRING): Name of the disk.
shm.bypassed.disk.fail.disabled
Deprecated
Severity
ALERT
This message occurs when three or more disks have been bypassed on a port.
Corrective Action
(None).
Syslog Message
shm: Disk bypass check has been disabled due to multiple bypassed disks on host bus adapter %s, shelf %d.
hba (STRING): Name of the host bus adapter.
shelf (INT): Shelf ID.
shm.bypassed.disk.fail.enabled
Severity
NOTICE
This message occurs when the bypass disabled state is cleared.
Corrective Action
(None).
Syslog Message
shm: Disk bypass check has been enabled for host bus adapter %s.
