shm.bypassed events
Creating your file...
shm.bypassed.disk.fail
- Deprecated
Deprecated as of Data ONTAP 9.3 because bypass code has been removed.
- Severity
ERROR
- Description
This message occurs when the system recommends that a disk be failed because it has been bypassed.
- Corrective Action
(None).
- Syslog Message
shm: Disk %s has been recommended for failure due to being bypassed by the shelf.
- Parameters
diskName (STRING): Name of the disk.
shm.bypassed.disk.fail.disabled
- Deprecated
- Severity
ALERT
- Description
This message occurs when three or more disks have been bypassed on a port.
- Corrective Action
(None).
- Syslog Message
shm: Disk bypass check has been disabled due to multiple bypassed disks on host bus adapter %s, shelf %d.
- Parameters
hba (STRING): Name of the host bus adapter.
shelf (INT): Shelf ID.
shm.bypassed.disk.fail.enabled
- Severity
NOTICE
- Description
This message occurs when the bypass disabled state is cleared.
- Corrective Action
(None).
- Syslog Message
shm: Disk bypass check has been enabled for host bus adapter %s.
- Parameters
