ONTAP EMS reference
shm.bypassed events
shm.bypassed EMS events occur when ONTAP encounters issues associated with bypassed disk operations.
shm.bypassed.disk.fail
Deprecated
Deprecated as of Data ONTAP 9.3 because bypass code has been removed.
Severity
ERROR
This message occurs when the system recommends that a disk be failed because it has been bypassed.
Corrective Action
(None).
Syslog Message
shm: Disk %s has been recommended for failure due to being bypassed by the shelf.
diskName (STRING): Name of the disk.
shm.bypassed.disk.fail.disabled
Deprecated
Severity
ALERT
This message occurs when three or more disks have been bypassed on a port.
Corrective Action
(None).
Syslog Message
shm: Disk bypass check has been disabled due to multiple bypassed disks on host bus adapter %s, shelf %d.
hba (STRING): Name of the host bus adapter.
shelf (INT): Shelf ID.
shm.bypassed.disk.fail.enabled
Severity
NOTICE
This message occurs when the bypass disabled state is cleared.
Corrective Action
(None).
Syslog Message
shm: Disk bypass check has been enabled for host bus adapter %s.
