The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
disk.partdisknotsuppmcc events
Creating your file...
Your file is ready
disk.partDiskNotSuppMCC
- Severity
NOTICE
- Description
This message occurs when a partitioned disk is found in a MetroClusterâ„¢ configuration.
- Corrective Action
Remove the partitioned disk, because it is not supported in a MetroCluster configuration.
- Syslog Message
Ignoring disk %s because partitioned disks are not supported in a MetroClusterâ„¢ configuration.
- Parameters
diskName (STRING): Name of the disk.
