ONTAP EMS reference
disk.partdisknotsuppmcc events
disk.partdisknotsuppmcc EMS events occur when a partitioned disk is found in a MetroCluster™ configuration.
disk.partDiskNotSuppMCC
Severity
NOTICE
This message occurs when a partitioned disk is found in a MetroCluster™ configuration.
Corrective Action
Remove the partitioned disk, because it is not supported in a MetroCluster configuration.
Syslog Message
Ignoring disk %s because partitioned disks are not supported in a MetroCluster™ configuration.
diskName (STRING): Name of the disk.
