The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
stackmon.stack events
Creating your file...
Your file is ready
stackmon.stack.id.conflict
- Severity
ERROR
- Description
This message occurs when the system cannot determine the stack ID for a disk shelf. The system has exceeded the maximum number of times it can change the stack ID of the shelf. The cause of this issue is a misconfiguration in the system.
- Corrective Action
Run the 'system health alert show' command and resolve all of the issues reported by following the corrective actions provided.
- Syslog Message
Stack ID of the Shelf %d (S/N %s) on channel %s cannot be agreed on by all the nodes in the cluster.
- Parameters
shelfIdent (INT): ID number displayed on the disk shelf OPS panel.
serialNumber (STRING): Serial number of disk shelf.
channelName (STRING): Channel connected to the disk shelf.
