stackmon.stack events
Creating your file...
Your file is ready
stackmon.stack.id.conflict
- Severity
ERROR
- Description
This message occurs when the system cannot determine the stack ID for a disk shelf. The system has exceeded the maximum number of times it can change the stack ID of the shelf. The cause of this issue is a misconfiguration in the system.
- Corrective Action
Run the 'system health alert show' command and resolve all of the issues reported by following the corrective actions provided.
- Syslog Message
Stack ID of the Shelf %d (S/N %s) on channel %s cannot be agreed on by all the nodes in the cluster.
- Parameters
shelfIdent (INT): ID number displayed on the disk shelf OPS panel.
serialNumber (STRING): Serial number of disk shelf.
channelName (STRING): Channel connected to the disk shelf.
