      repl.physdiff events
repl.physdiff.invalid.hole
- Severity
EMERGENCY
 - Description
This message occurs when a block to replicate was found to be inconsistent in the source volume. Replication has been aborted to avoid propagating the inconsistency to the destination node.
 - Corrective Action
Run wafliron on the aggregate containing the source volume of the replication.
 - Syslog Message
Replication of volume '%s%s%s' (DSID %llu) encountered an inconsistent block (VVBN %llu).
 - Parameters
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Unique identifier for the volume.
volDsid (LONGINT): Data set identifier (DSID) of the source volume.
vvbn (LONGINT): Virtual Volume Block Number of the affected block.
