shelf.config events
Creating your file...
shelf.config.mixed
- Severity
NOTICE
- Description
This message occurs at system boot time, when a stand-alone system's storage configuration is a mixture of redundant paths and single paths.
- Corrective Action
(None).
- Syslog Message
System is using a mixture of single path, multi-path or quad-path storage configurations.
- Parameters
(None).
shelf.config.mixedha
- Severity
NOTICE
- Description
This message occurs at system boot time, when an HA system's storage configuration is a mixture of redundant paths and single paths.
- Corrective Action
(None).
- Syslog Message
System is using a mixture of single path, multi-path or quad-path HA storage configurations.
- Parameters
(None).
shelf.config.mpha
- Severity
INFORMATIONAL
- Description
This event is generated at the Filer boot time, when it is a HA configuration and all the storage shelf enclosures accessible by the Filer have redundant paths. This message is for informational purpose only.
- Corrective Action
(None).
- Syslog Message
All attached storage on the system is multi-pathed HA.
- Parameters
(None).
shelf.config.multipath
- Severity
INFORMATIONAL
- Description
This event is generated at the Filer boot time, when it is a stand alone configuration and all the storage shelf enclosures accessible by the Filer have redundant paths. This message is for informational purpose only.
- Corrective Action
(None).
- Syslog Message
All attached storage on the system is multi-pathed.
- Parameters
(None).
shelf.config.qpha
- Severity
NOTICE
- Description
This message occurs at system boot time, when an HA system's storage configuration is quad-path.
- Corrective Action
(None).
- Syslog Message
System storage is in a quad-path HA configuration.
- Parameters
(None).
shelf.config.quadpath
- Severity
NOTICE
- Description
This message occurs at system boot time, when a stand-alone system's storage configuration is quad-path.
- Corrective Action
(None).
- Syslog Message
System storage is in a quad-path configuration.
- Parameters
(None).
shelf.config.single
- Severity
INFORMATIONAL
- Description
This event is generated at the Filer boot time, when it is a stand alone configuration and all the storage shelf enclosures accessible by the Filer have only one active path. This message is for informational purpose only.
- Corrective Action
(None).
- Syslog Message
System is using single path attached storage only.
- Parameters
(None).
shelf.config.spha
- Severity
INFORMATIONAL
- Description
This event is generated at the Filer boot time, when it is a HA configuration and all the storage shelf enclosures accessible by the Filer have only one active path. This message is for informational purpose only.
- Corrective Action
(None).
- Syslog Message
System is using single path HA attached storage only.
- Parameters
(None).
shelf.config.tomixed
- Severity
NOTICE
- Description
This message occurs in a stand-alone system when the storage configuration changes from a single-path, multi-path, or quad-path configuration, to a mixed path configuration.
- Corrective Action
(None).
- Syslog Message
System has transitioned to a mixture of single path, multi-path or quad-path storage configurations.
- Parameters
(None).
shelf.config.tomixedha
- Severity
NOTICE
- Description
This message occurs in an HA system when the storage configuration changes from a single-path HA, multi-path HA, or quad-path HA configuration to a mixed path HA configuration.
- Corrective Action
(None).
- Syslog Message
System has transitioned to a mixture of single, multi-path or quad-path storage configurations.
- Parameters
(None).
shelf.config.tompha
- Severity
INFORMATIONAL
- Description
This event is generated by the periodic storage health monitor process in a HA Filer configuration, when the Filer storage configuration changes from the single path HA configuration to the multi-path HA configuration.
- Corrective Action
(None).
- Syslog Message
System has transitioned to multi-path HA attached storage
- Parameters
(None).
shelf.config.tomultipath
- Severity
INFORMATIONAL
- Description
This event is generated by the periodic storage health monitor process in a stand alone Filer configuration, when the Filer storage configuration changes from the single-path configuration to the multi path configuration.
- Corrective Action
(None).
- Syslog Message
System has transitioned to multi-path attached storage
- Parameters
(None).
shelf.config.toqpha
- Severity
NOTICE
- Description
This message occurs in an HA system when the storage configuration changes to quad-path.
- Corrective Action
(None).
- Syslog Message
System has transitioned to a quad-path storage configuration.
- Parameters
(None).
shelf.config.toquadpath
- Severity
NOTICE
- Description
This message occurs in a stand-alone system. System has transitioned to a quad-path storage configuration.
- Corrective Action
(None).
- Syslog Message
System has transitioned to quad-path attached storage
- Parameters
(None).
shelf.config.tosingle
- Severity
INFORMATIONAL
- Description
This event is generated by the periodic storage health monitor process in a stand alone Filer configuration, when the Filer storage configuration changes from the multi-path configuration to the single path configuration.
- Corrective Action
(None).
- Syslog Message
System has transitioned to single path attached storage
- Parameters
(None).
shelf.config.tospha
- Severity
INFORMATIONAL
- Description
This event is generated by the periodic storage health monitor process in a HA Filer configuration, when the Filer storage configuration changes from the multi-path HA configuration to the single path HA configuration.
- Corrective Action
(None).
- Syslog Message
System has transitioned to single path HA attached storage
- Parameters
(None).
shelf.config.toTripath
- Severity
NOTICE
- Description
This message occurs when a stand-alone system changes to a tri-path storage configuration.
- Corrective Action
(None).
- Syslog Message
System transitions to a tri-path storage configuration.
- Parameters
(None).
shelf.config.toTripathHA
- Severity
NOTICE
- Description
This message occurs in a high-availability (HA) system when the storage configuration changes to tri-path.
- Corrective Action
(None).
- Syslog Message
System transitions to a tri-path HA storage configuration.
- Parameters
(None).
shelf.config.tripath
- Severity
NOTICE
- Description
This message occurs at system boot time, when a stand-alone system's storage configuration is tri-path.
- Corrective Action
(None).
- Syslog Message
System storage is in a tri-path configuration.
- Parameters
(None).
shelf.config.tripathHA
- Severity
NOTICE
- Description
This message occurs at system boot time, when a high-availability (HA) system's storage configuration is tri-path.
- Corrective Action
(None).
- Syslog Message
System storage is in a tri-path HA storage configuration.
- Parameters
(None).
