probedone.inquiry events
probedone.inquiry EMS events occur when the inquiry data fails the comparison at the domain validation (DV) step.
probedone.inquiry.failed
- Severity
ERROR
- Description
This message occurs when the inquiry data fails the comparison at the domain validation (DV) step.
- Corrective Action
Check whether the device is connected correctly.
- Syslog Message
In path %s, inquiry data fails comparison at the domain validation DV%d step of protocol type %d.
- Parameters
path (STRING): Device path.
inquirydata (INT): Comparison between the inquiry data failure and the domain validation, and whether the probe inquiry domain validation is type 1 or 2.
protocol_type (INT): Protocol type.
