ONTAP EMS reference
dbs.node events
dbs.node EMS events occur when ONTAP encounters issues associated with Distributed Block Store (DBS) node availability, such as maintenance mode or communication failure with the Cluster Master.
dbs.node.maint.mode.alert
Severity
ALERT
This message occurs when Distributed Block Store (DBS) detects a node with a maintenance mode failure.
Corrective Action
Contact NetApp technical support.
Syslog Message
DBS has detected a node with a maintenance mode failure. Cluster fault node %u, node UUID %s, type %s, fault ID %u, status %u. %s
nodeID (INT): Node ID number of the associated node.
nodeUuid (STRING): Node UUID string of the associated node.
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Details of the node in maintenance mode.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the CreateClusterFault API command and attached to the fault for testing purposes.
dbs.node.maint.mode.error
Severity
ERROR
This message occurs when Distributed Block Store (DBS) detects a node is in maintenance mode.
Corrective Action
Disable maintenance mode when maintenance is complete.
Syslog Message
DBS has detected a node is in maintenance mode. Cluster fault node %u, node UUID %s, type %s, fault ID %u, status %u. %s
dbs.node.offline
Severity
ALERT
This message occurs when Distributed Block Store (DBS) detects the Cluster Master cannot communicate with the master service on a node.
Corrective Action
Check for network connectivity issues and hardware errors.
Syslog Message
DBS has detected the Cluster Master cannot communicate with the master service on a node. Cluster fault node %u, node UUID %s, type %s, fault ID %u, status %u. %s
cfDetails (STRING): Details of the node offline.
