The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
disk.encryptgetmsidfailed events
Creating your file...
Your file is ready
disk.encryptGetMSIDFailed
- Severity
NOTICE
- Description
This message occurs when an encrypting disk reports a SCSI data protection error, but Data ONTAP® cannot obtain the Manufacturer's Secure ID (MSID) that is mandatory on disks that support storage encryption methods. Some conditions can cause this error temporarily.
- Corrective Action
If the error persists, replace the disk or remove it from the system.
- Syslog Message
Unable to obtain MSID from disk %s; status "%s" (0x%x).
- Parameters
diskName (STRING): Name of the disk.
status_string (STRING): Status code description from the SCSI driver.
status (INT): Status code from the SCSI driver.
