The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
spm.avs events
Creating your file...
Your file is ready
spm.avs.process.exit
- Severity
ERROR
- Description
This message occurs when the antivirus service stops running due to repeated failures. This can be the result of a bad or corrupted update in the scan engine library or virus definition files, or due to an internal failure. The failure of this subsystem can affect client access if mandatory scanning is enabled. It could also result in files not being scanned.
- Corrective Action
Disable and then reenable the antivirus engine. If the issue persists, contact NetApp technical support.
- Syslog Message
Antivirus server with ID %d exited as a result of signal %s. The service will attempt to restart.
- Parameters
id (INT): Process identifier.
cause (STRING): Plain text description of why the process exited.
