ONTAP EMS reference
disk.ioreassignfailed events
disk.ioreassignfailed EMS events occur when a disk reports a medium error and the sector reassignment fails.
disk.ioReassignFailed
Severity
ALERT
This message occurs when a disk reports a medium error and the sector reassignment fails. The system will fail the disk after possible recovery of retrieviable disk data.
Corrective Action
Replace the disk when the system indicates that you should remove it in subsequent logged events.
Syslog Message
disk %s: sector %llu failed to be reassigned (%d). %s
diskName (STRING): Name of the disk.
sector (LONGINT): Sector where the error was detected.
ETime (INT): Time, in milliseconds, from when the command was first issued until this I/O operation failed.
disk_information (STRING): Formatted information about the disk. This includes the disk's vendor, model, firmware revision, and serial number.
