ONTAP EMS reference
cr.rdb events
cr.rdb EMS events occur when ONTAP encounters issues associated with updating the replicated database with volume check scan information.
CR.RDB.Counters.Not.Updated
Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
Severity
INFORMATIONAL
This message occurs when the RDB (replicated database) cannot be updated with the inode counters for a particular scan.
Corrective Action
(None).
Syslog Message
The inode counters [percentage scan complete: %d], [estimated time remaining: %s], [number of issues detected: %d] and [number of issues fixed: %d] could not be updated in the RDB due to [error: %s] for [volume: %s] in [Vserver: %s].
percentComplete (INT): Percentage of the inodes scanned.
estimatedTime (STRING): Estimated time remaining for the scan to finish.
issuesDetected (INT): Number of issues detected by the scan so far.
issuesFixed (INT): Number of issues fixed by the scan so far.
reason (STRING): Reason for the failed update.
volume (STRING): Name of the constituent volume for which the RDB could not be updated.
vserver (STRING): Vserver hosting the volume.
CR.RDB.State.Not.Updated
Deprecated
Severity
NOTICE
This message occurs when the RDB (replicated database) cannot be updated with the final state of the scan, that is, success/failure.
Corrective Action
Run the 'volume check stop' command on the respective volume.
Syslog Message
The final state [%s] of the 'volume check' scan could not be updated in the RDB due to [error: %s] for volume [%s] in Vserver [%s].
state (STRING): Final state of the scan that has to be updated.
