cr.rdb events
Creating your file...
CR.RDB.Counters.Not.Updated
- Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
- Severity
INFORMATIONAL
- Description
This message occurs when the RDB (replicated database) cannot be updated with the inode counters for a particular scan.
- Corrective Action
(None).
- Syslog Message
The inode counters [percentage scan complete: %d], [estimated time remaining: %s], [number of issues detected: %d] and [number of issues fixed: %d] could not be updated in the RDB due to [error: %s] for [volume: %s] in [Vserver: %s].
- Parameters
percentComplete (INT): Percentage of the inodes scanned.
estimatedTime (STRING): Estimated time remaining for the scan to finish.
issuesDetected (INT): Number of issues detected by the scan so far.
issuesFixed (INT): Number of issues fixed by the scan so far.
reason (STRING): Reason for the failed update.
volume (STRING): Name of the constituent volume for which the RDB could not be updated.
vserver (STRING): Vserver hosting the volume.
CR.RDB.State.Not.Updated
- Deprecated
- Severity
NOTICE
- Description
This message occurs when the RDB (replicated database) cannot be updated with the final state of the scan, that is, success/failure.
- Corrective Action
Run the 'volume check stop' command on the respective volume.
- Syslog Message
The final state [%s] of the 'volume check' scan could not be updated in the RDB due to [error: %s] for volume [%s] in Vserver [%s].
- Parameters
state (STRING): Final state of the scan that has to be updated.
