ONTAP EMS reference
hypervisor.hyperthreading events
hypervisor.hyperthreading EMS events occur when hyperthreading is enabled on the hypervisor running ONTAP® Select.
Severity
ALERT
This message occurs when hyperthreading is enabled on the hypervisor. Hyperthreading must be disabled for ONTAP® Select support.
Corrective Action
Disable hyperthreading in the hypervisor configuration.
Syslog Message
Hyperthreading is enabled on the hypervisor, but it is not supported by ONTAP® Select.
(None).
