hypervisor.hyperthreading events
- Severity
ALERT
- Description
This message occurs when hyperthreading is enabled on the hypervisor. Hyperthreading must be disabled for ONTAP® Select support.
- Corrective Action
Disable hyperthreading in the hypervisor configuration.
- Syslog Message
Hyperthreading is enabled on the hypervisor, but it is not supported by ONTAP® Select.
- Parameters
(None).
