The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
configbr.nodesturl events
Creating your file...
Your file is ready
configbr.noDestURL
- Severity
ERROR
- Description
This message occurs when the cluster backup is saved on only one node and no offsite configuration backup destination URL is configured.
- Corrective Action
Configure an offsite configuration backup destination URL as soon as possible, using the commands "system configuration backup settings modify -destination <destination-url> -username <username-on-destination-url>" and "system configuration backup settings set-password".
- Syslog Message
Cluster backup is saved on only one node and no offsite configuration backup destination URL is configured.
- Parameters
(None).
