ONTAP EMS reference
configbr.nodesturl events
configbr.nodesturl EMS events occur when the cluster backup is saved on only one node and no offsite configuration backup destination URL is configured.
configbr.noDestURL
Severity
ERROR
This message occurs when the cluster backup is saved on only one node and no offsite configuration backup destination URL is configured.
Corrective Action
Configure an offsite configuration backup destination URL as soon as possible, using the commands "system configuration backup settings modify -destination <destination-url> -username <username-on-destination-url>" and "system configuration backup settings set-password".
Syslog Message
Cluster backup is saved on only one node and no offsite configuration backup destination URL is configured.
(None).
