configbr.nodesturl events
configbr.nodesturl EMS events occur when the cluster backup is saved on only one node and no offsite configuration backup destination URL is configured.
configbr.noDestURL
- Severity
ERROR
- Description
This message occurs when the cluster backup is saved on only one node and no offsite configuration backup destination URL is configured.
- Corrective Action
Configure an offsite configuration backup destination URL as soon as possible, using the commands "system configuration backup settings modify -destination <destination-url> -username <username-on-destination-url>" and "system configuration backup settings set-password".
- Syslog Message
Cluster backup is saved on only one node and no offsite configuration backup destination URL is configured.
- Parameters
(None).
