nameserv.config events
nameserv.config EMS events occur when a file write for name service configuration fails.
nameserv.config.write.failed
- Severity
ERROR
- Description
This message occurs when a file write for name service configuration fails.
- Corrective Action
Autocorrection is triggered for failing Vserver, configuration and node. Ensure that the root volume File System(FS) is available and has enough space and check the status using "vserver services name-service file-version show". Contact technical support if the problem persists.
- Syslog Message
%s configuration failed for Vserver %s on node %s.
- Parameters
vserver_name (STRING): Name of the Vserver.
ns_config_name (STRING): Name of the name service configuration.
node_name (STRING): Name of the node.
