The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mcc.ic events
Creating your file...
Your file is ready
mcc.ic.process.node.adv
- Severity
INFORMATIONAL
- Description
This message occurs when the MetroCluster(tm) config module receives a node advertisement from any of its partners.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
sys_id (LONGINT): System id of the node sending the advertisements.
is_local_node_assigned (INT): Boolean specifying whether the local node has joined the cluster.
is_partner_assigned (INT): Boolean specifying whether the node sending advertisements has joined the cluster.
