The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
sfu.suspendses events
Creating your file...
Your file is ready
sfu.suspendSES
- Severity
INFORMATIONAL
- Description
This message occurs when a disk shelf firmware update is requested in a high-availability (HA) environment. One partner node updates the firmware on the disk shelf module while the HA partner node temporarily disables enclosure services while the firmware update is in process.
- Corrective Action
(None).
- Syslog Message
Suspending enclosure services—partner is updating disk shelf firmware.
- Parameters
(None).
