dm.vserver events
dm.vserver EMS events occur when ONTAP encounters issues associated with Vserver configuration replication.
dm.vserver.mcc.rebaselinefailed
- Severity
ERROR
- Description
This message occurs when resynchronization of the Vserver configuration failed in a MetroCluster(tm) configuration.
- Corrective Action
Use the "metrocluster vserver resync" command to resynchronize the Vserver configuration.
- Syslog Message
Vserver configuration resynchronization failed for Vserver %s.
- Parameters
vserver (STRING): Name of the Vserver whose configuration is being replicated.
dm.vserver.sm.rebaselinefailed
- Severity
ERROR
- Description
This message occurs when resynchronization of the Vserver configuration failed in a Vserver DR relationship.
- Corrective Action
Use the "snapmirror resync" command to resynchronize the Vserver configuration.
- Syslog Message
- Parameters
dm.vserver.unlockfailed
- Severity
ERROR
- Description
This message occurs when unlocking the Vserver failed after resynchronization of the Vserver configuration in a MetroCluster(tm) configuration or Vserver DR setup. Management operations on this Vserver will fail, until an unlock operation is done by the admin manually.
- Corrective Action
Use the "vserver unlock -force true" command at diagnostic privilege to manually unlock the Vserver.
- Syslog Message
Vserver unlock failed for Vserver %s.
- Parameters
vserver (STRING): Name of the Vserver whose unlock operation failed.
