ONTAP EMS reference
wafl.blkreclaim events
wafl.blkreclaim.abort
Severity
INFORMATIONAL
This message occurs to inform you that the block reclamation scanner was aborted.
Corrective Action
You can disable this message as follows: setflag wafl_blk_reclaim_scan_log 0
Syslog Message
Block reclamation scanner was aborted on %s %s%s%s%s.
type (STRING): Type of object (volume/aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): Uniquely identifies the volume when the volume name alone is insufficient.
wafl.blkreclaim.complete
Severity
INFORMATIONAL
This message occurs when the block reclamation scanner is complete.
Corrective Action
Disable this message by running the 'setflag wafl_blk_reclaim_scan_log 0' command.
Syslog Message
Block reclamation scanner was completed on %s %s%s%s%s. The scanner took %ld ms.
type (STRING): Type of object (volume or aggregate).
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
run_time (LONGINT): Total run time of the scanner.
wafl.blkreclaim.noscan
Severity
INFORMATIONAL
This event is issued to inform the user that the block reclamation scanner was not started.
Corrective Action
This message may be disabled with: setflag wafl_blk_reclaim_scan_log 0
Syslog Message
Block reclamation scanner not started on %s %s%s%s%s.
type (STRING): The type of object (volume/aggregate)
owner (STRING): The volume owner
vol (STRING): The volume name
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
wafl.blkreclaim.reset
Severity
INFORMATIONAL
This message occurs to inform you that the block reclamation scanner was reset.
Corrective Action
Syslog Message
Block reclamation scanner was reset on %s %s%s%s%s.
