The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
fcvi.disabled events
Creating your file...
Your file is ready
fcvi.disabled
- Severity
ALERT
- Description
This message occurs when the HA interconnect card is disabled by the ic-type environment variable.
- Corrective Action
Either remove the HA interconnect card from the controller or change the ic-type environment variable.
- Syslog Message
FC-VI adapter: Port %s has been disabled because of the ic-type environment variable.
- Parameters
port (STRING): FCVI Interconnect NIC.
