ONTAP EMS reference
fcvi.disabled events
fcvi.disabled EMS events occur when the HA interconnect card is disabled by the ic-type environment variable.
fcvi.disabled
Severity
ALERT
This message occurs when the HA interconnect card is disabled by the ic-type environment variable.
Corrective Action
Either remove the HA interconnect card from the controller or change the ic-type environment variable.
Syslog Message
FC-VI adapter: Port %s has been disabled because of the ic-type environment variable.
port (STRING): FCVI Interconnect NIC.
