ONTAP EMS reference
fci.wrong events
fci.wrong.speed
Severity
NOTICE
This message occurs when the fixed speed level requested by the fc-force-XG-ports bootarg is out of range for the corresponding FC port.
Corrective Action
If another fixed speed is desired, adjust accordingly. Otherwise, the port will autonegotiate.
Syslog Message
Fibre Channel adapter port %s does not support a speed setting of %u Gbps, which does not fall within port range %x.
port (STRING): Name of the adapter port.
speed (INT): Speed the adapter port was assigned.
range (INTHEX): Range of speeds the adapter port is capable of using.
