repl.logical events
repl.logical EMS events occur when ONTAP encounters issues associated with data warehouse rebuilds and logical replication.
repl.logical.dw.rebuild
- Severity
INFORMATIONAL
- Description
This message occurs when a data warehouse is rebuilt as part of a SnapMirror® restore or resync operation.
- Corrective Action
(None).
- Syslog Message
A data warehouse rebuild was performed on volume with name %s, MSID %llu, DSID %llu, and Vserver ID %u.
- Parameters
volName (STRING): Volume name.
volMsid (LONGINT): Volume master data set ID (MSID).
volDsid (LONGINT): Volume data set ID (DSID).
volVserverId (INT): Volume Vserver ID.
repl.logical.lreTolrse
- Severity
INFORMATIONAL
- Description
This message occurs when previously enabled compression is disabled on the destination volume of a SnapMirror® relationship with the type XDP, and when it is followed by the "snapmirror update" command with the "enable-storage-efficiency" parameter set to "true". All future transfers to this destination volume from the current source will preserve storage efficiency as long as compression is disabled on it.
- Corrective Action
(None).
- Syslog Message
All future transfers from the current source to destination volume %s%s with MSID %llu, DSID %llu, from the current source will preserve storage efficiency as long as compression is disabled on the destination volume.
- Parameters
dstVolName (STRING): Destination volume name.
dstVolVserverUuid (STRING): Destination volume Vserver ID.
dstVolMsid (LONGINT): Destination volume Master data set ID (MSID).
dstVolDsid (LONGINT): Destination volume data set ID (DSID).
repl.logical.lrseTolre
- Severity
INFORMATIONAL
- Description
This message occurs when compression is enabled on the destination volume of a SnapMirror® relationship that has type XDP. All future transfers to this destination volume from the current source will not preserve storage efficiency.
- Corrective Action
(None).
- Syslog Message
All future transfers to destination volume with MSID %llu, DSID %llu, and Vserver ID %u, from the current source will not preserve storage efficiency.
- Parameters
dstVolMsid (LONGINT): Destination volume Master Data Set ID (MSID).
dstVolDsid (LONGINT): Destination volume Data Set ID (DSID).
dstVolVserverId (INT): Destination volume Vserver ID.
repl.logical.rawDirToLogicalDir
- Severity
INFORMATIONAL
- Description
This message occurs when a SnapMirror® transfer uses logical mode after a previous transfer to the same destination used raw directory mode. This most frequently occurs when the source node of the transfer was upgraded to a newer version of Data ONTAP® than the destination node.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
dstVolClusterId (STRING): Destination volume cluster Universally Unique ID (UUID).
srcInstanceImageUuid (STRING): Source transfer instance Snapshot(tm) copy UUID.
srcVersionImageUuid (STRING): Source transfer version Snapshot copy UUID.
rawDirsSupported (INT): Indicates whether the destination believes raw directory transfer is supported.
rawDirsRequired (INT): Indicates whether the destination believes raw directory transfer is required.
