telnet.enabled events
telnet.enabled EMS events occur when telnet is enabled in the cluster using the (privilege: advanced) "security protocol" command.
telnet.enabled
- Severity
NOTICE
- Description
This message occurs when telnet is enabled in the cluster using the (privilege: advanced) "security protocol" command.
- Corrective Action
(None).
- Syslog Message
Insecure protocol service telnet has been enabled in the cluster.
- Parameters
(None).
