The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
telnet.enabled events
Creating your file...
Your file is ready
telnet.enabled
- Severity
NOTICE
- Description
This message occurs when telnet is enabled in the cluster using the (privilege: advanced) "security protocol" command.
- Corrective Action
(None).
- Syslog Message
Insecure protocol service telnet has been enabled in the cluster.
- Parameters
(None).
