The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
zrto.lif events
Creating your file...
Your file is ready
zrto.lif.upgrade.failed
- Severity
ERROR
- Description
This message occurs when ONTAP® fails to re-create a previously deleted LIF during an upgrade. The LIF must be re-created manually.
- Corrective Action
Attempt the failed command again. If the problem persists, contact NetApp technical support.
- Syslog Message
Failed to re-create a LIF during upgrade. Command: "network interface create %s". Reason: %s.
- Parameters
command_arguments (STRING): Arguments of the command that failed.
error (STRING): Error that LIF creation encountered.
