      mgmt.rst events
mgmt.rst.fail.dst.compressed
- Severity
ERROR
 - Description
This message occurs when the SnapMirror® 'restore' command fails because compression is enabled on the destination volume.
 - Corrective Action
Force a cleanup of the failed operation by reissuing the 'restore' command with the parameter 'clean-up-failure', disable compression on the destination volume, create a Snapshot(tm) copy, and then reissue the 'restore' command.
 - Syslog Message
SnapMirror restore from source volume '%s' to destination volume '%s' failed with error: %s.
 - Parameters
srcpath (STRING): Path name of the source volume for restore.
dstpath (STRING): Path name of the destination volume for restore.
error (STRING): Error message.
