The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nblade.vscanconnbackpressure events
Creating your file...
Your file is ready
Nblade.vscanConnBackPressure
- Severity
ERROR
- Description
This message occurs when an AV server is too busy to accept new scan requests.
- Corrective Action
If this message occurs frequently, ensure that there are enough AV servers to handle the virus-scanning load being generated by the mentioned Vserver.
- Syslog Message
For Vserver "%s", AV server "%s" is too busy to accept new scan requests.
- Parameters
vserverName (STRING): Vserver associated with this operation.
scannerIp (STRING): IP address of the AV server.
object_type (STRING): Type of the resource object under notification.
object_uuid (STRING): UUID of the resource object.
