The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nblade.sharemaxconnlimit events
Creating your file...
Your file is ready
Nblade.shareMaxConnLimit
- Severity
ERROR
- Description
This message occurs when a CIFS share exceeds its maximum configured connection limit.
- Corrective Action
Increase the "max-connections-per-share" limit using "vserver cifs share modify" command.
- Syslog Message
CIFS share: %s of Vserver: %s hit its maximum connection limit.
- Parameters
shareName (STRING): Name of the CIFS share that the user attempted to connect.
vserverName (STRING): Name for the Vserver associated with this operation.
