ONTAP EMS reference
wafl.nfsv4 events
wafl.nfsv4 EMS events occur when the system cannot map an ID stored in the Access Control Entry (ACE) to a valid UNIX® User ID/Group ID (UID/GID) pair.
wafl.nfsv4.acl.not.mapped
Severity
ERROR
This message occurs when the system cannot map an ID stored in the Access Control Entry (ACE) to a valid UNIX® User ID/Group ID (UID/GID) pair. This failure makes this ACE an invalid one, resulting in a possible loss of access to the file or directory for which this ACE was set.
Corrective Action
Contact NetApp technical support.
Syslog Message
ID in NFS Access Control Entry (ACE) on inode number %x, file system ID %x could not be mapped to a user or group. Possible loss of access can result.
inum (INT): Inode number.
fsid (INT): File system ID.
